1/10 scale Pagani Zonda F roadster
everyonesgrudge
Messagepar everyonesgrudge » Sam Juil 04, 2009 5:07 pm
it was at the request of nico71 that I start a topic here on my Zonda. I am new to this forum and I cant speak french. so here it is. Its 1/10 scale has a 5+R gearbox with shift linkage, independent suspension with rocker arms and transverse mounted shocks and all the body work opens like the real thing. the engine also has intake and headers and full exhaust system as well. here is a link to My Zonda on MOC pages http://mocpages.com/moc.php/132401. My next car will be a 1/8 or 1/9 scale Shelby 427 Cobra.
Buldozer45480
Messagepar Buldozer45480 » Sam Juil 04, 2009 5:24 pm
good very good ;)
the car is beautiful
BIen, très bien ! ;)
La voiture est magnifique.
Messagepar Anio » Sam Juil 04, 2009 6:07 pm
Wooooo !!
This MOC is truly A-MA-ZING ! :loveyes:
I've recognized the Zonda at the first sight !!
The shape is really well executed. :o
And the exhaust pipes !! :loveyes:
But I must say that I don't see the gear box. :bizarre:
Is the wheel linked to the steering ?
Wahouu !!
Ce MOC est carrément HAL-LU-CI-NANT ! :loveyes:
J'ai reconnu la Zonda au premier coup d'oeil !!
La forme est vraiment bien rendue. :o
Et les pots d'échappement !! :loveyes:
Mais je dois dire que je ne vois pas de boite à vitesse. :bizarre:
Le volant est-il lié à la direction ?
PS : I suggest you to use the same color, like I did. Look there, in Sariel's topic to understand what does it consist in :
=> topic817.html
Actually, since you speak English, use these code :
Code: Tout sélectionner
[color=#FF0000][/color]
Et les membres qui parlent Anglais et Français sont priés de traduire eux-même leurs posts, en respectant également les couleurs (Anglais en rouge, Français en blanc). :grad:
everyonesgrudge
Messagepar everyonesgrudge » Sam Juil 04, 2009 6:20 pm
yes the wheel is linked to the steering. the gearbox is actually under the engine. I made a gearbox like the one from the 8448 super car, then flipped it upside down so the driving rings are on the bottom, then I made change over rods to select the gears, here is a picture
this was actually a different MOC, but it uses the same gearbox setup
Oui, le volant est lié à la direction. La boite à vitesses est sous le moteur. J'ai fait une boite à vitesses comme sur la 8448, puis je l'ai retournée pour que les driving ring soient en bas, ensuite il faut changer les axes pour sélectionner une vitesse. Voici une photo.
Sur la photo, c'est un MOC différent, mais qui utilise la même BV.
Messagepar Nico71 » Sam Juil 04, 2009 7:18 pm
Very good !
The system is the same on the Erik Leppen's Zonda.
Your next projet will be good to ;)
Le système est le même que sur la zonda de Erik Leppen.
Ton prochain projet s'annonce bien aussi ;)
mattis45
Messagepar mattis45 » Sam Juil 04, 2009 8:52 pm
I love this MOC :loveyes: , You are a very good MOCeur
J'adore ce MOC :loveyes: , tu es un strès bon MOCeur
