1:8 scale 427 Shelby Cobra chassis
everyonesgrudge
Messagepar everyonesgrudge » Mar Juil 14, 2009 6:09 am
Here is my finished 1/8 scale 1965 Shelby Cobra. its 19.25 inches long, 8.5 inches wide, and 4.9 inches tall. It has a 4 speed gearbox. This is the most detailed car I have ever made. I even went so far as to put in a fuel filler cap that is connected to the gas tank. the engine is fully detailed down to the serpentine belt on the engine. the engine also has a full intake with air filter, carburetor that has throttle linkage and is connected to the gas tank with a fuel line. I also made full headers and exhaust. The radiator is also connected to the engine. This is also quite possibly the quickest build I have ever done.
Voici ma Shelby Cobra à l'échelle 1:8. Elle fait 49cm de long, 22cm de large, et 12,5 de haut. Il y a une BV 4 rapport. C'est la voiture la plus détaillées que j'ai faite. J'ai aussi mis un bouchon connecté au réservoir d'essence. Le moteur a plein de détail, dont la courroie. Il y a aussi un carburateur, un filtre à air, des tuyaux jusqu'au réservoir. J'ai aussi mis les phares, les pots d'échappement. Le radiateur est connecté au moteur. C'est sûrement le MOC que j'ai construit le plus rapidement.
Messagepar Nico71 » Mar Juil 14, 2009 11:01 am
I prefer the viper but it's a beautiful model ;)
How long is the wheel base ?
Je préfère la viper mais c'est un joli moc. Combien mesure l'empattement ?
Stang67
Messagepar Stang67 » Mar Juil 14, 2009 11:03 am
RRraaahhhhhhh :loveyes: :loveyes: :loveyes: :loveyes:
(quoique elle serait encore plus terrible en bleu & bandes blanche... ::D: )
(she should be more terrific in blue with white stripes.... ::D: )
Ma collec de Lego
Messagepar Anio » Mar Juil 14, 2009 11:35 am
Han !! :loveyes:
That's great !
With the greebs you put on the engin, we can't see the cylinder. So, we don't see how fast the engin works (and consequently, we don't see the role of the gear box). It is a bit regrettable.
Very goo word anyway ! :resp:
PS : I've merged the 2 topics.
C'est super !
Mais avec les greebs que tu as sur le moteur, on ne peut pas voir les cylindres tourner. Donc on ne sait pas à quelle vitesse le moteur fonctionne (par conséquent, on ne voit pas ce que fait la BV). C'est dommage.
Quoi qu'il en soit, c'est du très bon travail ! :resp:
PS : j'ai fusionné les topics.
Messagepar Nico71 » Mar Juil 14, 2009 12:20 pm
Lego engine has sound, we can imagine the rotation per minutes but not covered the engine is not really realistic.
Les moteurs lego font du bruit, on peut imaginer la vitesse mais ne pas recouvrir le moteur c'est pas trés réaliste.
