[CONCOURS 11] Garbage truck Mercedes Econic
If you do not speak French, this section is for you !
LDW
Messagepar LDW » Dim Oct 02, 2011 5:19 pm
Hey.
I present to you Mercedes Econic:
Specifications:
2xl - drive
1XL -steering
1 RC -compressor
4M - 4 electrovalves
1 M -gearbox
8 large pneumatic actuators, 2 small actuators, 2 small pumps, 5 switches , 6 PF extension wire, 2 switches pf, 3 pairs of lights, 4 receivers pf.
Garbage truck is equipped with a lift to the bins, Trash Compactor, garbage ejection platform and rear lifting mechanism. The drive has a ratio of 5:1 and 1.7:1. 2xl but can not cope with the weight over 4kg, with the drive so I am not happy. Fully independent suspension. It is very soft, so the first and last axle further based on the axle.
http://www.majhost.com/cgi-bin/gallery.cgi?f=254121
Thank you.
camionmandaf
Messagepar camionmandaf » Jeu Nov 24, 2011 9:38 am
congratulation
Retourner vers Your MOCs
