Bridge building machine SLJ 50018
If you do not speak French, this section is for you !
WolfZipp
Messagepar WolfZipp » Dim Juil 28, 2019 5:58 pm
Hello, I want to present my ( well known ? ) MOC SLJ 50018
It is a functional model of the Chinese machine SLJ 90032
Image20130619084644_6093 by Wolf Zipp, auf Flickr
Image7398_2 by Wolf Zipp, auf Flickr
The machine is 92 m long , 7,5 m wide and 9 m high . The weight is 580 tons. It carry a 32,4 m long Bridge Segment with 900 tons.
Here is a long Video with all functions :
https://www.youtube.com/watch?v=190eH_AJeWQ
I build my MOC only from the Videos and a few Pictures .
I need about 1000 hours in 18 months to finish the MOC .
I build it with aprox. scale 1:25 , but with the half number of wheels, because fullsize would it 3,6 m long.
It is a full function model, not optical scaled.
13 Motors and pneumatic with 3 functions are on bord.
Self made cabel control box with switches incl. pneumatic Switches.
The Bridge box is no Lego , it has 2,56 kg weight., 60 cm x 36 cm x 8 cm
The model is 2 m long, 30 cm width and high, 10,5 kg weight.
ImageFunktionsbild by Wolf Zipp, auf Flickr
The Facts:
18 pair wheels 62,4 x 20 with starr axle. Separation was not able.
All wheels driven with 1 XL Motor for every Group ( 1 for 10 pair, 1 for 8 pair wheels )
All wheels turns with 1 L Motor / Group ( same )
Primare Support leg ( sliding leg )
Folding 1 L Motor with 2 LA in the leg
Lifting 1 L Motor with 2 LA in the leg
Sliding 1 M Motor with rope in the main beam
Freerun 1 Servo ( same )
Secundar Support leg
Folding 1 M Motor in the main beam
Lifting 1 L Motor with toothbar in the main beam
Winch 1 M Motor with 1 winch , 1 rope splitted to 8 ropes , to 4 hooks
Pneumatic 1 L Motor with 4 minipumps in 4 tact 90 ° different ( Modded from TechnicRobot.com )
Fake V 8 in 4 tact 90 ° different ( idea from Dave42 )
Pressure valve
4 big cylinder at ever wheel group
2 small cylinder for hook lock
not necessary : Parking stamp 1 L Motor with 2 LA ... this is result of a discussion , I let it inside because of the weight , for driving
Control box
9V power in , Switches for every Motor, 3 pneumatic Switches LEGO
3 AC Controller for drive and winch
Woodbox with selfmade display
Bridge
Styrodur with cement
There are some custom parts inside :
Cable extensions , long pneumatic tubes , ropes for the winches and the prestretching with metalhooks . and ballbearings for low friction sliding in the supportleg .
And the final Video :
WolfZipp
Messagepar WolfZipp » Lun Juil 29, 2019 8:45 pm
Hello, I think you want see some technical Details ?
The first step was : To get driven wheelpairs witch can turn 90° .
I want the wheels close together and tested some things with splitted axles, but they were not stabil.
So I took the left one with starr axle , fixed in a big turntable typ II .
ImageIMG_20180106_105154 by Wolf Zipp, auf Flickr
The steering get with the turntables
ImageFoto-0224 by Wolf Zipp, auf Flickr
The other drivetrain is splitted, because the cat with the supportleg have to drive through .
The first steps :
ImageFoto-0314 by Wolf Zipp, auf Flickr
And on paper with the leg with extesions
ImageFoto-0064 (2) by Wolf Zipp, auf Flickr
ImageFoto-0065 by Wolf Zipp, auf Flickr
And the other leg with Extension , build with 1x4 toothbars
ImageFoto-0042 by Wolf Zipp, auf Flickr
ImageFoto-0041 by Wolf Zipp, auf Flickr
Test in a longer part of the beam
ImageFoto-0067 by Wolf Zipp, auf Flickr
ImageFoto-0071 by Wolf Zipp, auf Flickr
Next Problem : folding the sliding leg ( It took many try and error to find the right System )
ImageFoto-0110 by Wolf Zipp, auf Flickr
ImageFoto-0105 by Wolf Zipp, auf Flickr
But the leg is too heavy, it doesn´t fly over the floor .
Next Problem : the cat slides not smoothly, because I use beams on the side.
I got a tip from a friend with the technicbeams und tiles to get a flat beam for the rolls .
I will continue ...
Messagepar Anio » Lun Juil 29, 2019 9:08 pm
Holy Moly. :o
I can see you gave a lot of dedication to that MOC.
Messagepar Free Bird » Mer Juil 31, 2019 12:17 am
I'm impressed by your bridge engine project and by your commitment to each step of the build. In gray, you haven't the same look of orignal, but it is still an achievement.
WolfZipp
Messagepar WolfZipp » Mer Juil 31, 2019 11:17 pm
Anio a écrit:Holy Moly. :o
Thanks Anio , yes it´s a lot heartblood and many rack my brains over this MOC .
But the machine is very impressive , so I thought almost every day about the next Solutions .
Free Bird a écrit:I'm impressed by your bridge engine project and by your commitment to each step of the build. In gray, you haven't the same look of orignal, but it is still an achievement.
Thanks Free Bird , it´s Grey , because the pannels were cheaper and the beamframes 7x5 and 11x5 were only arivable in Grey .
My model is not scaled , only build for functions .
Retourner vers Your MOCs
