Hello Yannmar,
I also want to congratulate you for your 42006-based excavator.
No extra needs as long speech to explain it you.
I'm rebuilding it, and encounters some lacks.
I hope you still have it build so you will easily save me
I got a lot of questions, mostly collected in the pictures below.
4 new photos from your model may answer most of them :
- left side, without pannel
- rear, without battery box or pannels
- top
- front, between the main-arm and the LA.
so pictures and questions now :
Left
1) What is pinned in thisz hole of . I cant see what is in the gearbox-encasement used
2) Here it seems an axle (other size too.) which lengs ?
3) What is pinned here, I miss a consolidading piece here ? Is it this ?
4) same question, which piece here
5) same question, which piece here ? Is it this ?
Top
6a +6b) What the piece here ? Highly probable some liftarm 5x3 or 4x2 ?
7) on the 5,5 axle, did the empty place remain empty, or did you fit a bush in ?
extra1) did you notice something uncomplete when looking at the gear-box encasement ? I'm not sure if they may be some liftarm going throuh from front to rear ?
Rear
8a + 8b) which piece here ?
9a + 9b) I notice your construct is mostly symetric, but : how is the 9a T pinned, just as I do with my 9b ? What about the lowest hole ?
10) What is pinned here ? I expect some "axle joinner with hole" thqt join axle that will comes from right and left, but it could be much more.At best a photo here.
Front :
11) Is it correct ? only the yellow connector and an axle-pin ? or is it something more complex ?
12) From your photos I can only expect this piece . Is it right ? how is her bottom fixation ?
13) That is THE Question. the rest is not so critical, but here : how it the main-arm-LA-transmission axle hold ? Here I didnt find any tips in your photos.
14) Is really the axle as long as I painted it ? Does it stop before the cabine ?
Cabine :
15) in the hearth of the transmission, through the cabine, I wonder if there is something missing ? some reinforcement ?
16) except if the axle of 14) really comes up to the cabine-commands, are the liftarm 5 only hold with the pin 3L ?
I hope you will see my post and be able to respond soon
Anyway, thanks for the nice model.
Best Regards,
gdbecane
