[CONCOURS 15] Lime buggy by LDW
If you do not speak French, this section is for you !
LDW
Messagepar LDW » Jeu Oct 11, 2012 10:32 pm
Hi there!
Lime Buggy for the competition 15 desert buggy:
Specifications:
lenght: 45cm
wight: 27cm
height: 20cm
weight: 1000g
fake engine: v8
gearbox: drive rings, 6 gears
steering: steering wheel, HOG
suspension: full pendular
drive: RWD
Construction is made ​​of beams and frames.
The suspension consists of a wishbone arms and shock absorbers
of set 8466. Transmission has been built straight. It consists
of drive rings and gears 12,16,20. Gear:
1. 7:1 (3:1 -> 1,7:1 -> 1,4:1)
2. 4.2:1 (3:1 -> 1:1 -> 1,4:1)
3. 2.4:1 (1:1 -> 1,7:1 -> 1,4:1)
4. 1.4:1 (1:1 -> 1:1 -> 1,4:1)
5. 1:1.25 (1:3 -> 1,7:1 -> 1,4:1)
6. 1:2.14 (1:3 -> 1:1 -> 1,4:1)
The drive is transmitted by the differential.
I am very satisfied with the suspension, very nice work (in my opinion :D)
Gallery.
Movies:
I'm sorry I did not write more but I can not speak English so good :P
Good luck in the contest!
Thank you. Regards.
Messagepar Anio » Jeu Oct 11, 2012 10:55 pm
You are the only one who used formula 1 suspensions. That's a very good idea.
The MOC is pretty good, especially when we consider that you took only few days to do it.
Good luck !
Messagepar Free Bird » Lun Déc 10, 2012 1:57 am
Wow, there is one of rare moc with "suggest lines" that i like. Because the spirit of trial buggy is the same : light weight, max suspensions, and minimalist cockpit with nice weels.
Sorry for my bad english.
Coool ! 8)
Retourner vers Your MOCs
